How to know security string and other details of my network.
Hi Experts!
I just purchased a wireless printer + scanner + fax machine 3 in 1 and trying to connect it to my laptop. It is asking me for SSID, security string, network name and password what to do now. Where I can find all these details. Thanks
Best Answer by Stella T Finley
Answered By 10 points N/A #168280
Press the start button your window you will see the run, click on run command.
Type "ipconfig" and press Enter.
The "Default Gateway."  Appear like “192.168.0.1" or "192.168.1.1." Close the command prompt.
Launch your Internet browser and enter your default gateway address into the address bar. Press "Enter." You will be prompted to enter the user name and password for the router access. If you do not know this check the "Default password List" online or consult your router's documentation. Log in. This will launch your router's admin pages.
Browse through the pages until you find the "Wireless security" section. Wording will vary depending on your router. Some phrases that will feature on the page will be "Wired Equivalent Privacy (WEP)" and "Wi-Fi Protected Access (WPA)." There will be two password fields on the page. Some routers will display the default wireless password here. If they do not set the wireless key to something you want to use. Click "Apply." You can now enter, either the existing or the new, security string during your Kodak printer setup.
Thanks,
Stella.
Answered By 55 points N/A #168281
Hello Todd K Graham,
You need to read the manual provided to you and also you have to search that thing on the Cd that is given to you with the device. You can get a step by step guide to the problem that you are currently facing. You have to put in place of SSD the address of your local host so that you can access your port. There you have to set the name and password of your network and after that you can do what you want with your printer
