nisha1prem
Posted on - 09/28/2011
We have win2k3 server. It is a Domain Controller. In that we installed Active directory. We have 15 users. One user changed his password. I am an administrator for this server. My question is how to know his system password?
saddam
How to know system password
Hello Nisha!
The domain controller you used is now out of reach to find his password. If you want to know about his password you need to re-install the program again. Rather you will not able to find him. Though you do not know about the password which he used, you have to compromise in there. Or you will try only add him at first time adding like
Add the partner>>put down the partner's ID>> Password.
This may solve you. Except re-install
You can use tracker on your computer. Then anybody who changes his/ her password you can read and you can control his/ her browsing system
Thank you!
Most password are encrypted. Administrator or not, when you create a password it'll be encrypted right away. This is standard to all log-ins, wherever a password is created, it'll be encrypted she moment they chooses a password. Some uses software that decrypted the password back to it's original characters when typing. However, you'll need to have this software downloaded and installed in your computer. This act like a spy that catches and record all characters that you have type in your keyboard. Add all this list of users under your control, list down all their current password and when they change it, you will get an auto-update of what they're password might be.
