Hello experts,
How to know Windows Server 2008 fan speed? There are some instances that we have to know the process in our computer servers or operating system in a way that we are aware of how does the process goes. I need some information regarding this, thank you.
How to know windows server 2008 fan speed?
Hi Kathryn,
Thanks for sharing your problem with us, If you want to check the fan speed you can use the speed fan program, Speed fan is a program that monitors the voltage, temperature, fan speed of the computer. Speed fan can access SMART info, it can even show the hard disk temperature. You can download the speed fan from the following link:
http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml
I hope this will solve your problem.
Hi Kathryn,
Fan Speed is a build in design in CPU it may add years to the life of your processor and computer servers. You can add fan controller in your CPU for managing and controlling temperature. You can determine your fan speed in two ways, one using the system BIOS and one using free software. Hope it will add to your information.
Best Regards,
