How to know the yahoo messenger dns address list? I just don’t know how to get those domain name server address list in my yahoo messenger contacts. Is there a way to get all the possible information? I need to block some user from my yahoo messenger that keeps on sending violent and horrible messages which is I don’t like.
Danield Make.
Hi, You don't need to have their domain address to block people from your yahoo contacts.. You can do it directly by logging into your yahoo account and blocking them from theirs.
But if you want to know the IP address of their server then go to command prompt and type ping https://www.yahoo.com/
You will get a list in which the first column is the IP of one of their servers.
Suenaku
Hi Dan,
 If you want to block some user from your yahoo messenger that keeps on sending you violent and horrible messages that you don't like. You can easily do that by:Â
1.) Login to your Yahoo messenger.
2.) Click on the word MESSENGER at the left upper corner which you can see on the pic with circled on red then follow the steps:Â
2.a. Go to preferences
2.b. Go to ignore list
2.c. Check the above where it stated ignore anyone not in your list.Â
NOTE: If the user is in your yahoo messenger list then you can RIGHT CLICK on the name of the user on your messenger list then choose the word DELETE, so that person will no longer be on your list and will automatically be ignored and you won't be able to receive any messages from that person. (since they are no longer on your list and you've just customize your settings to ignore anyone who is not on your messenger list)
I hope this helps on your problem/issue on your messenger btw, since I have that kind of issue personally from people that I don't know and was sending me horrible messages actually. It's also advisable you download or install an Internet Security on your pc, laptop or whatever you are using.
-Suenakuchan
