How to launch teamviewer via ssh?
Hello experts,
How to launch teamviewer via ssh? Share with me your knowledge about teamviewers for it is very necessary when building a business online. Some instances that will share your desktop information with your colleagues. I need your opinions. Thank you.
Best Answer by Carnaje fonseka
Answered By 5 points N/A #173545
First of all confirm that your pc network is on ‘Public’ mode.
Now install the sharing program called ‘jrdesktop’. It works best in broadband connections with many platforms at a time. Now try both the program and Teamviewer to connect by developing VPN through ‘reverse connection’. If you can do this, there will be no obstacle to use Teamviewer.
https://stackoverflow.com/questions/5458311/teamviewer-like-tool-for-ssh
Answered By 5 points N/A #173546
Hey Rebecca Green,
Running Teamviewer on Linux seems very painful thing because there is no version of team viewer for Linux. Even running it with Linux is a security risk. So, running it via SSH is a good if you care for the security of your connections. If you have SSH access to the machine you want to run TEAMVIEWER for, you should try the following commands:
  • Screen
  • Export DISPLAY=”:0.0”
  • Teamviewer6
If you have any further issues, get back on this link and post the reply so that we can provide you with the better solutions for your specified problem.
Thanks
