How to learn croping for psd soldier face crop
To customize crop a soldier face in a PSD format using photoshop, follow these steps.
1. Open your Photoshop tool
2. Go to “File” control panel and choose “Open”
3. Choose and open the photo you want to crop
4. Use the “Zoom Tool” in the tool panel and move the zoom spectator area over the face you want to appear.
5. Choose the “Pen Tool” on the device list and affix points all over the feature you want to crop. Secure points on trimmings of bending lines.
6. Choose the opening point and it shall shut the path.
7. Hit Right-click on the “Pen Tool” and choose "Add Anchor Point" tool.
8. To generate a good outline, click on the central point of course
9. Hit “Ctrl” while moving the point until the arch is well in shape.
10. To show the outline around the crop image do Right-click on the face and choose “Make Selection”.
11. To get rid the face of from the photo Click on Delete.
Hi Mark Maxwell,
You want to crop soldier face only or include background?
Here some solutions for you:
Include background: you can use one of these ways:
Use Crop tool:
– Select crop tool on toolbox
– Drag to draw a rectangle over the face
– Scale, rotate the rectangle until you get the size you want
– Double click or press Enter to finish command
Use command Crop:
– Use any selection tool (rectangle, ellipse, lasso…) to make a selection over the face
– Go to menu Select > transform selection to resize your selection until you get the size you want
– Go to menu Image > Crop
The face only:
– Use any selection tool (suggest magnetic lasso) to make a selection fit to the face. Then go to menu Image > Crop
– Or use pen tool to make anchors fit to the face. In order to close path, click on the first anchor. Pen tool will make a path (vector), not a selection. You need to convert this shape to selection by press Ctrl + Enter. Then go to menu Image > Crop
For more information about pen tool, use Ctrl when you want to move anchor, use Alt when you want to control direction of the next path segment.
Hope this helps
