Hi all experts,
I was using a Dell Inspiron laptop for the last few years, but now it's a battery creating problem. The battery is not giving any charging back-up. Now I am thing to buy a new Lenovo ideapad g565 laptop, as I have heard the battery back-up of Lenovo is too good. Please give your opinions on this laptop.
How is lenovo Ideapad g565 laptop.
Good day Toby,
I believe I will be able to help you find the solutions you need. The Lenovo ideapad g565 is quite a good laptop in performance, display and mobility. The laptop is evaluated below average although it is quite a good laptop to use and in quality. The laptop is also usually lighter than the average of all notebooks. This gives it an advantage to the other laptops.
The laptop battery however as you suggest is one which is not the best of the laptop batteries. However this depends also on the price you buy the battery.
The laptop is however rated best in overall performance. I would recommend it.
I hope this solves your query.
