I am using Visual Studio C Builder and other compilers except mingW/gcc. I need to know how the Math GL library is linked. Also I need to know about building Math GL in Windows. It is to be created GLUT/FLTK/QT windows with calculation in parallel.
How to link the MathGL library
To link mathGl libraries you can include the header file #include <mgl/mgl_w.h> which contain c++ wrapper classes and recognized by any compiler.
You can use the CMake which is utility to compile C code. This is required because all the mathgl are build in pure C and required a CMake + MinGW utilities to build all the libraries under windows. Along with the package you may also need few more graphic related packages such as GSL , PNG , JPEG etc to build. All these packages can be found and downloaded in the website http://gnuwin32.sourceforge.net/packages.html
You can create parallel calculation by creating separate thread for processing window messages. You can you the GNU libraries Pthread library to create thread in generic way. Data can be updated using the function mg1graphFLTK::update().
Please find a sample code for your reference:
#include <mgl/mgl_fltk.h>
#include <pthread.h>
#include <unistd.h>
mglPoint pnt;
int sample(mglGraph *gr, void *)
gr->Box(); gr->Line(mglPoint(),pnt,"Ar2");
return 0;
void *mgl_fltk_tmp(void *) { mglFlRun(); return 0; }
int main (int argc, char ** argv)
mglGraphFLTK gr;
gr.Window(argc,argv,sample,"test"); // create window
static pthread_t tmp;
pthread_create(&tmp, 0, mgl_fltk_tmp, 0);
pthread_detach(tmp); // run window handling in the separate thread
for(int i=0;i<10;i++) // do calculation
sleep(1); // which can be very long
pnt = mglPoint(2*mgl_rnd()-1,2*mgl_rnd()-1);
gr.Update(); // update window
return 0; // finish calculations and close the window
