How to list the addons Explorer 8?
Hi, I am having Internet Explorer 8 installed in my laptop. I know I have installed a plenty of add-ons. Is there a way that I can list all addons Explorer 8?
Thanks in advance for your answer.
Hello Abbigailantonia
You can check all the plug-ins that are available in your internet explorer 8 by following the steps below:
1) First open Internet Explorer either on the start menu or in your installation folder.
2) On the tools button click on the manage Add-ons option.
3) Once that is opened go to Add-on types and click Toolbars and Extensions.
4) Then go to Show and choose All Add-Ons, this will display a list of all the add-ons you have in your Internet Explorer.
Hello Abbigail,
To see all the add-ons you have installed in Internet Explorer please follow the following steps:
1. Open your Internet Explorer from the start menu or double click on Internet Explorer icon.
2. Go to tools -> Manage add-ons-> Enable or disable add-ons.
3. Go to the Show list.
4. Select add-ons currently loaded in Internet Explorer
A list will appear in front of your screen which will show you the add-ons you have installed.
