How to listen mp3 from Galaxy ace using bluetooth.
I have a galaxy ace which functions well but i need to listen mp3 even when it is not near me. Can you please advise me on how to listen mp3 from my galaxy ace via Bluetooth?
You can play your music and listen to them using Bluetooth. There are some headphones which are controlled by Bluetooth. You can connect to the headphones via Bluetooth and play audio files and listen to that. Every Bluetooth utility accomplished device allows this service. You can also use a wired headphone if you like. But it will be better for you.
You would need to pair your Bluetooth headset with your Samsung Galaxy Ace. Here’s how it can be done.
• On your Samsung Galaxy Ace, access App Drawer.
• Select ‘Settings' icon.
• Go to ‘Wireless and networks'.
• Choose ‘Bluetooth settings'.
• Tick ‘Bluetooth' checkbox.
• Make sure your Bluetooth is turned On and discoverable.
• Now hit ‘Scan devices'.
• Your Bluetooth or Device name should show up. Tap to connect.
• It may require a passcode to connect which should be indicated in the User’s Manual.
Congratulations! You have successfully paired your Bluetooth with your Samsung Galaxy Ace.
If you want to listen to music with your phone via Bluetooth, you just need to buy a Bluetooth headset like this one on eBay: V9 Wireless Bluetooth 4.0 Headset. Here are the specs of your phone.
The Samsung Galaxy Ace S5830 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies measuring 112.4 x 59.9 x 11.5 millimeters and weighing 113 grams.
It uses mini-SIM card and has TFT capacitive touchscreen display with 16M colors at 320 x 480 pixels screen resolution protected with Corning Gorilla Glass featuring TouchWiz UI 3. It ships with Android 2.3 Gingerbread powered by Qualcomm MSM7227 Snapdragon S1 chipset, 800 MHz ARM 11 processor, and Adreno 200 GPU. It supports microSD expandable up to 32 GB.
It runs on 278 MB RAM with 158 MB internal storage. The primary camera supports 5 megapixels with AF and f/2.6 featuring LED flash. It supports 480p video recording at 24 fps. There is no secondary camera.
It has 3.5-millimeter jack featuring DNSe sound, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML. It runs on removable Li-Ion 1350 mAh battery with standby time up to 640 hours on 2G and 420 hours on 3G.
Talk time is up to 11 hours on 2G and 6 hours 30 minutes on 3G. It is available in black, white, Hugo Boss Edition, and La Fleur colors.
