How to Load Garmin Map for HTC?
Good day! I recently bought HTC tablet as I want to be connected to all my contacts across the globe. I just wanted to know how to load Garmin mapfor HTC. Thank you very much!
Hello Jerold,
Here is the guide how can you load Garmin map on HTC
First download the Garmin and click on the program. Then follow the prompt to configure your mobile so that it can share GPs signal through activesync. Then go to start menu and select programs-activesync-menu. After that follow prompts to edit information about GPs.
Now go to your GPS settings then go to GPs port. Now set baud rate to 4800 in GPs tool. This rate indicates or determine in per second how many times the communication channel signal changes.
There you go. Restart your phone and open Garmin maps.
