How to load up my Macosx cd recovery?
How to load up my Mac OS X CD recovery? I made some format with my Mac operating system computer desktop and it was a successful one. I made a backup of those important files in my business company and I stored it in a CD, how would I load it back up again in Mac OS X? A step by step process is needed.
Lindsay Wendy.
Best Answer by Wuest Kiro
Answered By 0 points N/A #183356
The answer of your question is too long. If I post my answer in this post I think you cannot understand. So for that I suggest you to visit: http://email.techradar.com/files/amf_future_publishing/workspace_62/MacLife/ml_v2.3.html
I hope by visiting this site you can solve your problem. On that site there is a detail description of Mac CD set up. They give the whole details about your question on that site. You also learn many other things about the Mac installation from that site.
Nipa
Answered By 0 points N/A #183357
"Hi Lindsay Wend,
I want to help you in loading up your recovery CD.
I hope this would help.
Once you already back up and stored the files on a CD
1. Insert the disk and open Recovery Disk Assistant
2. Select the files which were deleted or were lost to recover them.
3. The software CD and DVD Recovery will automatically scan the disk.
4. Once the scan finished, Choose the files documents and database you want to recover.
5. When you’re done Click Save and it’s good to go. Just choose the folder or location where you’re going to send the files in.
