How to locate and change my SQL file icon
I would like to add my SQL file icon in my Sharepoint Server, preferably the one that looks like a notepad with SQL on it. I'm having a hard time locating it on the web and on my computer. Can anyone help me locate that SQL file icon?
Best Answer by Raun Nelson
Answered By 0 points N/A #195936
Hi!!
Your question is very important to all. I have explored the perfect solutions.
Firstly you need to install Reporting services.
Then the Sharepoint server should be set up.
Then you should check the SharePoint management. It should not be Powershell.
You must run the Powershell as an administrator.
Then you need to install ‘Reporting services add in for sharepoint product’
Then add the sql component to your SharePoint.
Thanks
Nowell
Answered By 0 points N/A #195933
Hi Doriswneil,
You are working hard to write each SQL query on a notepad so you should do that when you write SQL query the right click on that page go to view source and copy all source and next time if you want to that query so you can run that and the second method is that you can transfer by using drop box and transfer application. Hopefully this information will help you.
Thanks,
Raun Nelson
