I want to know how to automatically lock my Windows 7 computer, when I’m out or when I’m away for a short period of time. We have kids in our house and they always play with the computer. I have work to do and I do not want them to turn the PC on and off.
This will be a waste of time. So I want to know if there is a way that I can lock it, while I’m not on my desk. Help!
ann12
How to lock my computer when I’m away?
There are many people who find that turning on and off the computer to be a nuisance and that is why there are now methods to help one keep the computer on but in an inactive state.If you want your computer to be inaccessible to others but still on. you can just follow a very simple steps
After using the computer and you want to go out first of all ensure that you computer has a password protection at log on that is not known to the kids.
Click START
Click Log Off
the computer will log off and anyone who tries to log in will be asked for a password. When you comeback just put in the password and all the programs that were running will continue.
This action is sometimes required, to keep your computer secure when you are away or not at your desk. This is possible with Windows 7 and we will be doing this by personalizing your screensaver settings. To get started please follow the steps below:
Right-click anywhere on your desktop and then select Personalize to open the Personalization settings.
Select Screen Saver.
Alternatively, you can access your Screen Saver settings without using your mouse, just hit the Win key on your keyboard ; then enter Screen saver on the search box and press Enter ; then select Change screen saver.
This will also open the screen saver settings box.
Select your desired Screen Saver, then check the box “On Resume, display the logon screen” when you exit your Screen Saver , then click Apply then OK.
After your selected length of time, your screen saver will appear as normal.
When you move your mouse or press any key on your keyboard, your logon screen will appear instead of directing to your desktop. If you have input a password on your User Account, enter it on the logon screen and your desktop will now appear.
To lock your computer without a screen saver:
Right-click anywhere on your desktop and then select, Personalize to open the Personalization settings.
Select None on the screen saver option then check the box On Resume, display the logon screen” and then click Apply then OK.
After your selected length of time, your logon screen will appear as normal.
Type your password ; then OK to go to your desktop.
hillsong
To restrict your computer, you need to set a password.
To do this:
Go to Start>Control Panel
Select 'User Accounts and Family Safety' button in the dialog box that appears.
Enter a Username in the text box provided then select Administrator user type. This sets you as the only user to the computer.
To enforce that, create a password that is easy to remember but difficult to guess.
Click Create Account to complete registration.
When leaving the PC at the desk, always press Windows key+ L to log off, after which anyone must provide a password to access your PC.
Hi Frank,
You can anytime lock your computer by using ctrl+alt+delete. Or for automatic lock of Windows 7 go to :
Click on Start.
Click on Control panel.
Click Power Options.
Click on Require Password on Wake up on the left pane.
Select the option Require a password.
Windows 7 will automatically lock your computer after 5-10 minutes, and go to sleeping mode status.
Thank you,
Mary.
You are all very effective. This works like magic. My worries are all gone. Thank you so much!
