ashley.bila
40 points
Posted on - 08/31/2013
Hi All,
I am using Windows 7 and would like to know about how to lock your mouse in place, in order to avoid movement of the mouse during presentations.
Please provide the method of locking of a mouse.
Thank You, Ashley Bila
How to lock your mouse in place
Hello Ashley,
I have a suggestion to make.
When you are presenting, you will inevitably need to use the mouse before you finish your presentation.
Therefore, instead of locking your mouse, you can reduce the mouse speed to the minimum.
This is equally good as locking the mouse.
1. You can do this by searching for the control panel on the start page.
2. Click on the control panel and search for mouse.
3. Click on pointer display or speed.
4. Drag the cursor to the slowest and click on Ok.
I do hope this helps.
Regards.
