saiful_3d
10 points
Posted on - 04/15/2012
I m a freelancer worker with also a blogger. I very much like Blogging and Facebook using. I have also some Facebook account. Sometime I need to two or more Facebook account log in for Facebook sharing because of web site SEO. So that I try to log in one more Facebook account at a time. But that will not possible. have any add-ons which help me to Multi-login at Mozilla Firefox.
N.B: For multi-login, I have to use more browser like Firefox, Chrome, IE-8, opera etc. That make me very disgusting. At this moment, I want any advantage, which are able to multi-login at a time at one browser. Basically preferable Mozilla Firefox.
How to Log in two+ Facebook account at a time
Did you know that you can open two Facebook accounts in a time. There are two steps in two face book login account in a one time.
First is – All you need is two browser installed in your computer. And open the first browser to login your Facebook account.
Secondly is – Than open the other browser. After opening Facebook login type the login.
Info of the other account.
One of your two accounts will open.
This is how you can open your face book accounts in a one time.
Hope this could help you with your problem. This extension is only compatible with the lower version of Firefox, for me I use Firefox 3.6.28. And also you can use it on opening multiple emails.
1. Download the extension freely from https://www.nektra.com/files/cookiepie.xpi.
2. Install the new extension.
3. Navigate it using the tab context menu. Right click within the tab and choose Toggle On/Off CookiePie.
4. You will know that it is already enable because you will see a little cookie on the right side of the tab.
5. Then go to the address bar and type https://www.facebook.com/ and login to your profile. Just recently made this two profile for testing.=D
