How to LogMeIn through vb6
Please tell me how I can use logmein through vb6. I have logmein installed but I still have not figured out how I can use it with vb6. Is this possible? How? Help please…
LogmeIn is a tool developed by a company to support remote desktop connection and you cannot do any modification or access their utilities through your own programming. Basically the answer for your question is no. if the software is for open development then you’ll be able to download and do your own modifications with the source code but this is a commercial product and you’ll be not able to do that kind of stuff without the permission of the owner.
What you can achieve by the software is the functions provided by them and if you need to about the development stuff about the software you should contact their customer support and they might be able to help you.
