How Long Do Game Codes Bought On Amazon Take To Expire?
When buying a code for a game on Amazon, how long does it take to expire? If I buy it now, will the code I give to my son still work on the 25th December 2021?
According to users on answers.microsoft.com, the code should work perfectly on the date you want and on any date. Game codes, normally, don’t have expiration dates. Unless it is noted, you will see the expiration date indicated on the code itself on the website or if you receive it. For users who are not familiar with what a game code is, a game code is also called digital code.
It is like a voucher you use to redeem something. For example, you buy a game on Amazon. Amazon will send you a confirmation email verifying your purchase. Amazon will also send you another email containing the code. You will then need to go to the PlayStation store and log in to your account.
Click your avatar at the top of the screen then select “Redeem Codes” from the dropdown menu. Enter the code carefully then click “Redeem.” After that, you will now be able to download the game you purchased. That’s how a game code works.
Notifications
