How to lunches asp net batch file
I have questions about asp net batch file I really need a pointers on how to run batch file that launches a series of automation tests on QTP. The batch file contains a vbs script path and it takes three parameters. Each time someone needs to run the automation, I have to do this manually. What is the best way to achieve what I want?
Thank you so much.
