Hi all friends,
I have all HD videos on my laptop, but now I wanted them in my mobile. I wanted to be converted all videos to mobile format and the quality should not change.
Please suggest me how to convert video format in acdsee add codec without compromising with the quality.
How to maintain HD quality in Acdsee add codec video convertor.
Hi Dallas,
There are several software that you can convert any HD video file to be compatible with your mobile phone without changing quality and other issues like aspect ratio. "Aiseesoft Total Video Converter.6.1.18" is one of them and a pretty good one in my opinion.
This software allows to you to convert any HD video (720p, 1080p) file for mobile compatible format without changing the quality.
This software support almost all video formats and also support GPU acceleration.
I converted many video files with this software without any problem.
Good day.
