How to make 3D effects in Photoshop?
Asked By 110 points N/A Posted on -
I've been seeing a lot of graphics design that I never knew that it is possible to make it in Photoshop. I've seen glass ball, 3D text, and a lot more. Can anyone here know about this? Please share tips in doing those things here! thanks!
Best Answer by Karen Li
Answered By 0 points N/A #88572
So the Basics in making your image into 3D or Realistic view is that you should have these 3 key elements: Shadow, Highlights and Midtones. So imagine a red apple with a lighting effects on its side. Now, you would notice there would be a 3 significant colors: Red, bright red, and dark red. These are what I am talking about. So in making your image 3D like, you should have sufficient knowledge on these.
Answered By 0 points N/A #88573
There is one simple trick you can use! After creating your text or any other images or shapes in Photoshop, click on the blending options and choose Drop shadow and Inner glow. This can instantly make your text or image to a 3D look! Try it for your self!
Answered By 0 points N/A #88575
That's a nice idea on this article, thank you very much EXPERT Raquel Roxane. it helps me a lot.
Answered By 110 points N/A #88577
The two methods definitely works! though the 1st method is time consuming but it is really helpful when time comes you want to do it manually! Thanks a lot for your help guys! Are there anymore tutorial you can share to me?
Answered By 0 points N/A #88578
You can also use the dodge and burn tool. The dodge can make the pixels look brighter and on the other hand, the burn makes the pixels look darker. So use the burn tool in making shadows while dodge in making highlights. Please remember in using realistic light effects to effectively make your image stand out.
Answered By 0 points N/A #88579
For the metal effect tool. Try using the blending option of the layer and select gradient overlay. Choose the color black and white to produce a metal effect. This too can make it look 3D especially if your image is something to do with metals.
Answered By 110 points N/A #88580
Great! This helps me a lot! I hope you guys can continue help me whenever I have other questions. Thanks!
