How to make all my connection like a big bridge connection
I am using two Broadband connections and Modem like Citycell net connection and sometimes Qubee or Banglalion Modem. I want all of the connection to become a bridge connection.  I never used a bridge connection but I think it is so fast and useful to me  when I make a bridge connection.
How can I make a bridge connection?
Puja
Answered By 0 points N/A #87508
Hi Puja,
here are the instructions that you follow to make a bridge connection.
Open the network connections, look for LAN or High speed Internet ; then hold and press down the control (CTRL) key ; then you can now choose the adapters that you want to include in the bridge.
Then Right Click the connections that you chose. Then click the bridge connection. You must have two network connections in order to create a bridge connection and you can only create one network bridge on a computer, but the bridge can create many network connections.  I hope that this will answer or provide the solution to your question.
Thank you!
