jabez zion
10 points
Posted on - 11/06/2012
Good day everyone. I have a problem with this app inventor radio streaming shoutcast. What I want to do is create a shoutcast stream app with the app inventor. So far, my code has worked successfully on the emulator but I couldn’t get it to work with any other real device. Any idea how to solve this? Thanks.
How to make app inventor radio streaming shoutcast
Hello Mr.Jabez.
App Inventor will play streaming audio just fine.But you have to use the blocks editor to set the player source to the URL of the stream — it won't work to set it in the designer.
You'll need to use a URL of an actual audio stream. These can be tricky for find, since most of the URLs you find on music sites point to the player or to a playlist, not to the actual stream.
– Right click on a station link, then save the .pls file and look at the corresponding url contained
-or-
– View the page source and click on any of the links that start with "http://yp.shoutcast.com/sbin/tunein-station.pls?id=XXXXXX" and look at the urls in the playlist text file
If you have a URL and want to test whether it's a stream, you can use iTunes if you have Mac and go under advanced -> open stream, and try to play that URL.
Thank you.
