How to make AT&T call from Skype?
I want to call international long distance from my smart phone.
I want to do this by AT&T call of Skype.
How can I do this?
How can I do this?
Skype is available on smart phones which have dual camera or you can face the camera and screen at the same time just like iPhone 4.
And yes, Skype is available on AT&T phones but it should be with for mentioned requirements.
You can download Skype iPhone app which is available for iPhone 3GS or above from here.
One more thing which you should check about your smart phone is multitasking. It will make easier to use Skype. If you are using iPhone 4 or iPhone 3GS, by using multi tasking feature, you can run Skype in parallel with other application.
In this case Skype will run as background process.
Hope this will answer your query.
Feel free if you have any query.
Regards.
Hello Charles Bowers,
My pleasure to giving you these tips.
Find your IPhone IMEI number and note it.
Then take a call AT&T by dialing 1-800-335-4685 and then dial 0010 for immediate response of representative (Skip the hold time)
Now you can request to be unlocked your IPhone. You just have to present your IMEI number and wait a movement for the instruction email. It will point a request to unlock your IPhone. You have to restore the IPhone via ITunes to finish the device unlock. While unlocking, a micro-SIM provided by T Mobile or other compatible network is working with the IPhone.
I hope this is the solution what you ask. So please try this to solve your problem.
Thank you.
