How to make audio DVD with Nero 10 ?
Dear Experts
I am interested in making an Audio DVD. Tried a lot but cannot do it. I think something is missing in my process. I use Windows 7. Can anyone tell me how to make audio dvds with nero 10?
Dear Experts
1. Click on the "Start" button . Select "All Programs" and go to your DVD burning application. You can download online if you do not have one yet or should you want to try other platform.
2. Launch the application by double clicking on the program name. Push the Open or Eject button on DVD drive, Insert your disc where you want the audio file burnt. Close the cd drive.
3. On your burning application window, Click on the music note symbol and Select the option for "Music DVD".
4. Search for the audio file you want to burn to your DVD and then drag it to the application window.
5. Under Options, Tick the check box for your preference on how you want the audio file played whether you want it shuffled, playback, etc.
6. Click the red button which states "Burn" and wait until the burning process is completed.
Notifications
