vibe daly
Posted on - 08/19/2016
Hi. I am a school-going student. I have a lot of interest related to the computer hardware. I am planning on preparing a recovery disk for my PC. I use Windows 8. How to make a backup disk for Windows 8? Please reply ASAP. Thanks in advance.
How To Make A Backup Disk For Windows 8 In Simple Steps
.Hi. To learn how to make a backup disk for Windows 8, first click on search option. Then, type recovery drive in the search option and then click on create a recovery drive option. After the tool opens, ensure that the option of copying the recovery partition to the recovery drive from the PC has been selected following which click on next. After this, a USB drive which has the size that has been mentioned needs to be inserted into the PC. You need to select the drive which you would like to use for the recovery drive and then click on next. Select the create option to create the recovery disk. All the tools and recovery images will get transferred to the drive.
After the process is completed, either click on finish if you want the recovery partition to be retained on the PC or if you want it to be deleted, then click on delete and after the disk space becomes free, click on finish. Then, remove the drive safely. It can used in future to reset the PC. Ensure that it is kept at a safe place and do use it to store other files.
Hope we helped.
