How To Make A Barcode In Excel Using These Simple Steps
Hi. I have recently started learning MS-Excel so I am not very comfortable with it. I need to prepare a barcode list which needs to be submitted to the Office. How to make a barcode in Excel? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #200418
Hi. To learn how to make a barcode in Excel, first open MS-Excel from the start menu. Next, click on the add-ins tab. Then, open the panel of tbarcode. Select a cell and keep the cursor there. Select the type of the barcode that you would like to have. In the selected barcode, either enter the data or use the default data to be inserted in it. Adjust the barcode’s size according to your need and then to insert the barcode, select the insert barcode option.
To create the barcode list as was desired by you, first open the spreadsheet in MS-Excel either with the default data or create a new list altogether. Then, open the tbarcode menu and the cells containing the barcode data should be selected. Next, select the type of barcode you want to use and finish the process by clicking on the insert barcode option.
Hope we helped.
