My original window DVD can’t be used any more as it has many scratches. So I need to make a bootable DVD of the window image, I tried this twice but failed both the times. Please help me in creating this DVD step by step. I heard there are many a software to make bootable DVD, if it is so, then please name a few of them.
How to make a bootable DVD of window 7
Making a bootable DVD is fairly easy.
1. You will need to take the ISO image file of windows 7 and place it on your computer (any location).
2. Insert your new DVD into the drive and start your burning software (NERO or whatever you are using).
3. The option you must select here is Copy Image to Disc and then select the windows 7 file from that location where you stored it.
4. Go ahead with the burn process and wait till it finishes.
Your new bootable windows 7 DVD should be ready.
