How to make bootable USB for Windows
I have a laptop and cd drive of my laptop is out of order now i want to install operating system in it for that purpose i want to make my SB bootable can anyone tell me How to make bootable USB for windows.
Hi
To be able to use USB for OS installation, you first have to configure the BIOS to select your USB device as the first boot option. This can be done by accessing the BIOS menu. To access this menu, Press either the del, F2 or F12 key. This depends entirely on your machine. Once you have made USB to be your first boot device, you now need a bootable usb mass storage containing the operating system you want to install. The are several software that can be used to make a bootable disk. My favorite is Hirens Bootable CD. From here, the rest of the procedure is normal.
Hi Jeremy Slaterable,
It is very easy to install an OS using a Bootable Pendrive. You should follow these steps:
1. You should set USB as First Boot configuring the BIOS setting.
2. You should Create a Bootable Pendrive. You will find many Software that can make Bootable Pendrive.
Normally I use "Ultra ISO". You can get it from this link.
i) Format Your Pendrive.
ii) Use any ISO file of an Operating System to make Bootable Pendrive.
3. After Creating Bootable Pendrive, Just restart your Laptop.
Then OS installation will begin.
Thanks
