How to make a bootable windows CD?
I want to make a bootable CD for my windows xp but I don't know how. Will you guys tell me how can I make my CD bootable?
Also, please help me with the best software for burning CD.
Hey Jovan Clayton!
The best software to create a bootable CD of windows XP is Nero. You can download this software from the internet. After downloading the software, Launch it. After launching it, follow these steps:
1. Close the Nero Wizard (If it opens).
2. You will see CD types in New Compilation window. Here you have to select CDDVD-Rom (ISO) and after that click on ISO tab.
3. Now Drag your Windows files (.ISO) from browser window to the right pane.
4. Now there you will see a Recorder Button, click on it.
5. In the new window that opens, select Image Recorder and click the Ok button.
6. Now click on File button on the upper toolbar and select Write CD.
7. Here check the Write properties and click on Write button.
8. Now give the name to the image. and click on Save button.
9. The process of Burning will start now.
10. Once the process is complete, restart the computer and check whether it boots from the CD or not.
Thanks
Hello Jovan Clayton, Well this is very interesting and I might ask you why going for XP? Apart that you will be needing some files and procedure to complete your requirement. Below are the steps you need to follow:
You will be having in depth details of the procedure. Thank you
