How to make call through Skype?
Hi, I'm using the latest version of Skype.
Here i noticed an option to make call to phone/mobile phone.
But i'm not sure if the settings is okay to make a call in Phillophino?
I need some help. Thanks.
Log into your Skype account, from there go to your make calls tab, once there a keypad, rates for calling every country, and buy Skype credit will appear,
In the keypad window choose the flag of the country that you would like to call and then you can either type the number or keypad the number next to the flag.
Click the green call button and the call should start.
Yes calls are able to made to and from the Philippines..
Ive also included an attachment with pictures to show you step by step what to do
Hi, Ariel
It’s very easy to make a call using Skype application.
Please follow these steps:
Thanks and regards,
Skarbos Jay.
Hello Ariel,
To learn making calls, first try a test call. This is a good way to test your settings and equipment's working.
There is a service available as Sound Test Service.
To make a test call please follow the instructions:
1. Open Skype and log in with username and password.
2. In the contacts area you will see the Echo/ Sound Test Service, select it.
3. Now options will appear on your screen. Click the Call button.
4. Now just keep following the audio instructions to complete your call.
Now to make a Phone call. You can do it by going to the option Call Phones, at left side of your screen.
Click to select. Enter the phone number and click on the green phone button.
This will do the calls for you.
Thanks
Hello there,
In all Skype desktop software the calling system is same.
First, login into your user account using the desktop software interface. Now from the left side of the window select any contact which is online now.
Than in that window a page will appear which actually creates a session between your interface and his interface.
Now on the new page you will get two green buttons there you will get call button. Now just click on the call button and the calling session will start, if the opposite user pickup the call then you can talk on that session.
Thank you,
Riley Weaver.
