How To Make A Church Bulletin In Word In Some Simple Steps
Hi. I am new to the concept of MS-Word. I want to create a church bulletin. How to make a church bulletin in Word? Please reply ASAP. Thanks in advance.
Hi. To learn how to make a church bulletin in Word, first open MS-Word. Click on the file menu and then select new. Select the templates from Office.com. Then, click on a category after which the related links of images will appear. Then click on the image to look at its zoomed version. Then click on the download option and the template which has been selected by you will appear on a new document in MS-Word. Then click on one of the line in the document and then click on delete option so that the sample text can be removed.
On the line which has been selected, type the text. Then, the other text boxes should be updated as well. Then, type bulletin instead of the agenda title. After all the changes have been done, save the document by selecting the save option which appears in the file menu.
Hope we helped.
Notifications
