How To Make A Circle Graph In Excel In Simple Steps
Hi. I am a new user of MS-Excel. I want to prepare a pie chart in Excel for my holiday homework. How to make a circle graph in Excel? Please reply ASAP. Thanks in advance.
Hi. To know how to make a circle graph in Excel, first open MS-Excel. Enter the data which you require so as to create the pie chart. Then create a data series which is simple because that is what the pie chart needs to be created. Save the spreadsheet selecting save from file menu. The next part is of highlighting the data by clicking on the cells containing the information which needs to be included in the pie chart.
Then, click on insert and select the chart option from all the options which appear in the list. Next, select the type of pie chart which you want which can be either regular, 3D or some other kind of a pie chart. After all this is done, click on OK. Save the spreadsheet by clicking on the file menu and then select the save option.
Hope we helped.
