Hello techyv,
How to make computer table designs for gaming?
I want to use Adobe CS5 Photoshop version in making computer table designs for gaming.
This is what I am planning to put in the banner space for my website.
Me and my friends are planning to organize a gaming forum and we need this for the website banner.
Please give me some advice about the proper layout.
Expecting some help from you guys.
Thank you.
Hi Davis;
I have seen a lot designs of computer table but this one is really incredible and heart touching.
I suggest you to use Adobe Illustrator to design a computer table because its auto shape tool indeed works great.
If you visit ultimate computer setups from home-designing,
I hope you would change your mind about Photoshop designing and desire to purchase one of them.
Hello Davis Millers,
I have realized the point of your interest.I am giving a significant solution.
You can design a computer table for gaming in Adobe Photoshop. But it is better to take a snap of such a table.
Then edit the photo. A sample photo is attached to this. You can edit as required.
In Adobe Photoshop firstly you have to divide the layers in the photo.
Then you will go to filter. Liquefiers as required. You can use Gaussian Blur
This tip will be more effective.
Regards
Shifflett Laurel
