How To Make A Database In Microsoft Excel?
I have a set of data in Microsoft Excel which is perfectly arranged. I want to create a database with the help of it. How can I make a database in Microsoft Excel?
You can create a database in Microsoft Excel by using any third party database software. To do the same, follow the given steps:
1. Using Microsoft Excel, create your data.
2. Click on “File” and choose “Save As.” Select the “Save as Type” drop down option and choose the format of your file that your database program supports.
3. Close Microsoft Excel and run your database program. 4. Import your Microsoft Excel spreadsheet into your database program and convert it into the database following instructions of the respective database software.
