How to make dos data backup storage?
Dear Techyv members, I hope you are all well today. If this is not too much to ask, may I ask about your help on how to make dos data backup storage effectively. What are the steps needed for this kind of backup? Do I need to download anything? Your specific answers are highly appreciated.
Answered By 5 points N/A #137768
Hi! MSDOS is an application where allows you to backup any data from your computer. MSDOS 6.22, 6.21, 6.2 and 6.0 supports the ms backup command. But if you are using MSDOs 2. x from 5.00a don't worry you can still backup your files because it has backup.exe and backup.exe comes as external.
For MSDOS 2. x and 5. x, here is the syntax
Backup [source:PathFilename][Location][/s][/m][/a][/d:date][/t:time][/f:size][/L:LogDriver:PathLog]
