How to make EFI boot flash drive?
I was able to do this in Ubuntu but making it work in Windows 7 is a such a headache. I doubt if the PC is the issue. It is an HP Compaq Elite 8200 Microtower. Has anyone of you done this?
Please forward guidelines.
Thanks
Answered By 60 points N/A #193176
Hi, Hall Allen
I am concerned with your problem, that's why I made a brief research about it. It is seemed that you are not the only  user who experience this problem. There are a lot of forum  that tackles about it. Some forums have ideas and tips/ways on how to solve this matter.
I can suggest you a good forum, which are listed below:
Hope that it helps you a lot with your problem.
Thanks and more powers.
