Evin Gizmo
20 points
Posted on - 03/24/2012
I want some pictures in my website to fade in / fade out after certain interval but I can't figure out how to do this. I know that
with the help of Javascript, it can be done. But I wanted to learn some other easy way to do this. Any suggestions?
How to make fade in and fade out pictures?
Well another way to do this is to use a html code. You are right when you say that javascript is involved, because you will need jquery javascript, but the html code will make your images do what you are wanting. Since you have stated that you do not want to do java there is another way. If you are familiar with myspace and other pages you wîll notice that you can suse à regular html code that will fade in and fade out your pictures.
You can use the following javascript code for the required job.
var t
var j = 0
var p = Pic.length
var preLoad = new Array()
for (i = 0; i < p; i++){
  preLoad[i] = new Image()
  preLoad[i].src = Pic[i]
function runSlideShow(){
  if (document.all){
     document.images.SlideShow.style.filter="blendTrans(duration=2)"
     document.images.SlideShow.style.filter="blendTrans(duration=crossFadeDuration)"
     document.images.SlideShow.filters.blendTrans.Apply()    Â
  document.images.SlideShow.src = preLoad[j].src
  if (document.all){
     document.images.SlideShow.filters.blendTrans.Play()
 j = j + 1
  if (j > (p-1)) j=0
  t = setTimeout('runSlideShow()', slideShowSpeed)
</script>
This code will display images continuously with slide show and fade effects.
