How to make a good quality content for my web?
What can you suggest for me to have a high quality web content, to have a web site with a high traffic?
High quality content of a webpage bring high traffic to your website,it is true. At the same time some other things you have to perform. You should have a nice,valuable and enjoyable content on your site first.
Because these contents will bring back the visitors and their friends. To make your content more effective you have to think of a nice niche first that about you are going to write. Then do research on this topic and make some plan. Invite your friend or some one to view your content and asked them about the quality.
You can also ask your visitors what they would like.You have to give attention to visitors choice.Use webmaster tools to know what keyword or topics are searched. After all your site should be well designed and should make impression to visitors mind.And again the most way to getting visitors by search engines.
So you have to do some SEO.
If you are planning to create a website and you expect it to receive high traffic then you should put great amount of contents. The traffic you receive depends on your site’s contents. Your site’s contents should be among those that are well accessed or well downloaded by different users.
Examples of contents that are popular to users are MP3, video, applications, games, and so on. Populating the site with your contents usually takes several months that’s why creating a site is pure sweat and patience. If you think your site already has considerable amount of contents, you may consider putting it on ads so it can be advertised and reach different users all over the world.
Advertising is sometimes the key in the popularity of the website. Creating backlinks also helps other users reach your site. You can hire other people to personally put backlinks on different sites that will direct users to your website. Meta tags also helps using the right keywords for your site.
The keywords that are added to meta tags help search engines find your site easily. The keywords should also be the words that best describe your site or the contents that users can expect from the site. Examples of meta tags are found below:
The first meta tag describes your website and the second are the keywords.
