How to make grasses easily by 3ds max.
I have the software 3ds max I want to make realistic grass. How can I make it? Thank you for your answer.
Hi there, if you have 3ds max then you can imagine that you have the entire thing to make 3d things. It is world’s top 10 3d rendering software, and also it is a huge one. In 3ds max you can make grasses in many ways. I explain the easiest way. First run your 3ds max software then create a plane shape as a soil where your grass stands. Then selecting the plane go to modify panel in the left of you. Click on the dropdown menu and select on to the hair and fair (WSM). Now go to “tools >(under preset) load > and select “tall grass” from the upcoming window. Now render with f9 button. That’s it.
