How to make an iPad a hotspot in these simple steps
Hi. I do not belong to the computer field. I have recently purchased an iPad and I want to prepare a hotspot on it. How to make an iPad a hotspot? Please reply ASAP. Thanks in advance.
Hi. To learn how to make an iPad a hotspot, first click on the icon of settings on the iPad. Next, to open the network settings of iPad, click on network and then select general. In the menu of network settings, select the option named personal hotspot after which a personal hotspot will appear in front of you. On the menu, there will be an off button will needs to be tapped so as to switch it on. An absence of this button indicates that hotspot is not supported on the iPad. You can get this feature added to your iPad. Next, enter a password which is known by the devices with whom you are making a hotspot. The password must be strong and at least eight characters in length. The password cannot be in any other language. It must be a combination of the ASCII and Unicode characters strictly. Hope we helped.
