How To Make A Logo In Microsoft Word?
I want to create a temporary logo for an event but I don’t have the knowledge on how to use graphics designing software like Adobe Illustrator. How can I make a logo in Microsoft Word?
Microsoft Word can be easily used to create a simple logo. You can create a logo by the following steps:
1. Insert a shape in MS-Word using the Insert tab.
2. Format the shape by using Shape Fill, Gradients, and Shape Outline.
3. Insert text using WordArt and format it using text effects,etc.
4. Select both the text and shape together by pressing Ctrl and clicking on them.
5. Then go to Format tab and group them together and then cut them using Ctrl+X.
6. Then right click and paste them as a Picture.
