Angela King
10 points
Posted on - 01/21/2013
I need to download the Microphone Boost for my Windows 7 PC, where can I download the software for it? It is present when using my Windows XP PC, but I want to download it for my Windows 7. Please send me the link. Thanks.
How to download the Microphone Boost for Windows 7?
Hello Angela King,
If I understand correctly, you need to boost your computer's microphone, well you don't need any additional software as there is a built-in option in Windows 7. Please follow the instructions below:
– Click Start > Control Panel > Hardware and Sound > Manage Audio Devices
– Under the Recording Tab, double click on your Microphone to display its Properties.
– If there is a Custom Tab, click on it and Check the Microphone Boost box.
– If there is no Custom Tab then click on Levels Tab and adjust the Microphone Levels.
