How to make my browsing faster?
i'm using windows 7 since then im using internet explorer that comes with my computer. is there a way to surf the internet faster?
I've understand your problem. Here are some tips for this:
Tip 1:
i. first you go to start menu and then choose run.
ii) After you choose run,it appears a little box,then you can type regedit.
iii)Find the key that you need by following this
HKEY_CURRENT_USER Software Microsoft Windows CurrentVersion InternetSettings
iv)On the right box,right click and choose new ,then continue choose DWORD Value
v) type into the box : MaxConnectionsPerServer
vi) Just right click on that key and choose modify,and then type the value that you want into the value box(when you type the large number then your browser faster)
vii) create another key such as MaxConnectionsPer1_0Server (do the same the above steps)
Now just close every thing and restart your computer,then run your Internet Explorer again, see what happen
It should be run faster than usual.
Tip 2:
1. Click start > Run
2. Type regedit > Enter
3. Browse folder HKEY_CURRENT_USERSoftwarem*ro$oftWundowsCurrentVersionInternetSettings
4. Right click … then windows right > New > DWORD
5. Type MaxConnectionsPerServer > You can set value here.
6. Create another DWORD and type MaxconnectionsPer1_0Server.
7. Then enter any higher values here.
8. Then restart your pc.
Hope this tips will help you a lot.
Download an Internet surfing accelerator application; there are many free tools out there, such as the Google Web Accelerator. These programs can help you speed up your Internet experiences as well.
Notifications
