josep craig
Posted on - 12/15/2012
Hi experts,
Could you please suggest how to change the color of the mouse pointer in the desktop ?
How to make my mouse pointer black
Hi Mr. Josep,
It is so simple to change your mouse pointer color to black.
Please follow the below steps.
1. Go the start.
2. Click on control Panel
3. Double click on mouse option.
4. Now mouse properties window will appear.Click on pointer tab.
5. See the scheme option,there is a list of mouse option in drop down list.
6. Please select windows black (large)(system scheme)
7. Apply and OK.
Hello Joseph,
There are couple of ways to change the white pointer to black pointer.
It's good for visibility purpose. Here are some ways to change your cursor style or color.
Method 1:
1. On your desktop using your mouse press the right click button.
2. Go to > Personalize.
3. On your left, choose the Mouse pointers.
4. Choose the black pointer.
5. Save the settings.
6. Press Ok.
Method 2:
1. Go to Start > Control panel > Mouse > Pointers
2. Choose your desired Pointer.
3. Save the settings.
This will solve your issue.
Thanks
