How to make my windows pointer in WIN7 Ultimate bigger
Hi all,
I'm starting to feel old, and my eyes are getting the best of me.
I was wondering if you tech folks out there know how to make my windows pointer in WIN7 Ultimate bigger?
Cheerio!
Hi all,
Cheerio!
Hello There!
I'm sorry to hear you are having difficulties looking for the mouse pointer. (Me too!)
Don't worry! I'll help you out (& its rather easy too!)
1. Right click on your wallpaper (or desktop)
As you can see a new window popped up.. Go ahead and click on "personalize".
2. You will get a window that sort of looks like this:
Click the "change mouse pointers" link and you'll get another window..
3. Click on the "Scheme" drop down list and pick any scheme that you might fancy on.
I would suggest using the Extra large inverted one so you wouldn't miss it.
I hope I was able to help!
Sincerely,
Paul Pinalb
One of the ways is as properly explained by Mr. Paul above.
By personalizing your windows 7, you can discover many changes indeed.
I also have a software named Cursorfxpro, it provides you with a lot many varieties of big and small pointers.
Using this software, you can just change the design of your present mouse pointer into a hand or anything that may be suited to your vision.
Notifications
