Hello fellows,
How to make or create a slide background Joomla? Joomla was introduced by my friend that is easy and reliable when it comes to webpage creation. But still I am not yet familiar with the software functions and features. Help me to create a slide background using Joomla.
Curtis Marry.
How to make or create a slide backgrounds joomla?
In Joomla You Can Do That By Putting Module. And After You Find The Right Module Install Then Adjust The Module For What you want it Look Like. Here Is One Of Extension Module:
https://extensions.joomla.org/extensions/extension/style-a-design/page-background/bt-background-slideshow/
After You Download Install The Module In Joomla.
I will Put How To install A module
Unpack the compressed .Zip file onto the local hard drive before uploading it via FTP. Ideally the file should be transferred to the joomla_root/administrator/components/com_installer/module/yourmodulename directory of Joomla!.
Once the files are uploaded enter the exact location of this file (it must be the absolute location) in this example: joomla_root/administrator/components/com_installer/module/yourmodulename then click the Install button.
The new Module will be installed by Joomla! In the joomla_root/modules/yourmodulename directory of the web site.
