How to make a postcard in Microsoft Word 2010?
Hi, I want to create a card for a business invitation, and I want to keep it easy on the technical part. So, can anybody assist me with the procedure of how to make a postcard in Microsoft Word 2010!
To create a postcard in Word 2010 is quite easy. Here you can read the step-wise guide with proper illustrations:
• Open a new MS Word document.
• Go to New menu under the File tab, and then click on Cards folder. Now, choose Postcard that you want.
• Next, enter the information required, add images/pictures, and replace the logo icon on the postcard with your own.
• Fill all the sheets in the front and the back, and Save the project.
• Preview your Postcard image, and if satisfied, you can take its print out.
