How To Make A Poster In Word Manually?
I need to create a professional poster for my college event. It should look much better than the ones we create by our hands. Does anyone know how to make a poster in Word?
If you want to make an attractive and catchy poster for your college event, then you can make it by creating a box and formatting it according to your need in MS Word.
Follow the steps to get started:
• Open the application.
• Go to Format tab, and then click on ‘Borders and Shading’.
• Select the page settings, and style and thickness of the border
• Use Word Art for the title of your poster.
• Now, select the Text Box from the toolbar, choose the appropriate color and outline for the box.
• Insert the picture for more effectiveness.
• Continue the steps until the desired poster is ready.
• Take the print out after previewing.
Notifications
