How to make a “QuickBooks skins” ?
I want to make a "QuickBooks skins". I have researched on internet to learn but I haven't. learned it. I need to learn it as soon as possible. Can anyone help me to learn how to make a "QuickBooks skins" ?
Madly.
Best Answer by Davidson Mudge
Answered By 0 points N/A #157852
Hi, Madly!
I have researched on how to create your own QuickBooks Skins, but sad to say, there are still no available information on the internet or is it even available for use. There are available QuickBook skin downloads if you would like. But as of now, there is no way for you to create your own skin. I suggest you just to download the available ones or stick to the original.
Answered By 0 points N/A #157853
Hi Madly,
         Quckbooks Skins can be downloaded online, just check the Quickbooks website. If ever you are having problems with the skins you can also change the color scheme in your Quickbooks. Just go to Edit – Preferences – Desktop View and then look for “Color Scheme”. You can also match the scheme with the windows outside of Quickbooks just go to Properties > Desktop tab and look for the scheme.
